Dimension invisible while in sketch
javelin_exile
javelin_exile
there's been a bit of weirdness since the last update. this has happened to me before though but I can't ignore it so I need a solution. working on a component in a large assembly i'm trying to define a sketch and when I select the dimension tool t lets me select the points but the dimension is not visible. Video attached
javelin_exile
I found if I isolate the component, then I can add the dimensions normally. still would like to know why
g-andresen
1. Are the elements that you want to dimension in the active sketch?
2. Please share the file.
File > export > save as f3d on local drive  > attach to post.
günther
