Create a Spiral Around a non-circular profile
jasonhomrighaus
Message 1 of 10
jasonhomrighaus
   Im trying to figure out if there is a relatively quick/Automated method to create a spiral around a nonuniform shape.  Essentially Im trying to "wrap" a hose around a rectangular ish object and get a relatively accurate model of said wrap.
Any thoughts?
Jason
Replies (9)
Message 2 of 10
davebYYPCU
Surface Sweep with twist angle.
Trim with wrapped object,
Pipe.
Might help….
Message 3 of 10
jasonhomrighaus
I see that but I want to make 16 wraps, sweep only allows for 1
Message 4 of 10
TrippyLighting
You can sweep angles larger than 360 degrees. I usually multiply 360 times the number of revolutions I want.
Message 5 of 10
davebYYPCU
Now you tell me….
16 hoses or 16 revolutions of one hose?
Message 6 of 10
g-andresen
Sweep > twist = 16+360°
günther
Message 7 of 10
jasonhomrighaus
16 wraps of a single hose.
Message 8 of 10
jasonhomrighaus
looking for wraps like this.  A quick way to create this kind of wrap around a non uniform core. 
This was made using a ton of offsets, then a lot of editing to add fillets in the outer layers. so rather frustrating and time consuming.
Message 9 of 10
jasonhomrighaus
see previous reply for the nature of the sweep im trying to accomplish
Message 10 of 10
jasonhomrighaus
see above for an example of the desired result
