Create a scale around a cylinder
I'm trying to create a scale around a cylinder, e.g. as used on the hand-wheel of a lathe.
This is my starting point https://a360.co/2BPKOQd
I can create a sketch for a single line and extruding to cut the cylinder then create a series of engraved lines using a circular pattern. I can even do this with patterns in arcs - the second scale is the metric equivalent of the first.
My problem comes when I want to engrave text around the cylinder to line up with the check lines, e.g. the numbers 0 through 9 aligned to each of the major check lines in turn. I've looked at various proposed solutions online but can't see anything that would scale in the same way as the creation of the engraved lines.
