Create a model with material thickness that you can be changed and model will update?
InfoKCN98
InfoKCN98
Hi All,
We are looking to create products using a specific material thickness (wood), but some times due to availability we need to buy a slightly different material thickness. Is there a way to input the material thickness so that it can be updated and the model will then automatically update to that?
g-andresen
You can achieve this by defining the maaterial thickness as a variable in the parameter list and assigning it in the design.
The design is then adjusted according to the current material thickness.
günther
TheCADWhisperer
@InfoKCN98 wrote:
Hi All,
We are looking to create products using a specific material thickness (wood)...
@InfoKCN98
You could use Sheet Metal tools (even though the material is not metal, think sheet goods, uniform Thickness).
You can set up the Thickness rules.
You can go back and forth between standard tools and sheetmetal tools and use the Thickness parameter.
laughingcreek
I suggest attaching an example model that you would like to do this with (export as a .f3d and attach).  how well this works is highly dependent on how well the model was made.  there can be a learning curve for that.  working thru an example with folks here can help you along with that.
etfrench
Is this a machining question or a modeling question?  Is the material always thicker than the final product?
ETFrench
