Fusion360 on macOS 14.6 Mac Mini M2 Pro seems unstable / crashing on extrude once a week or two
ovisopa
ovisopa
Hello everyone,
I switched to Mac a few months ago, but since than it seems once a week or two I work in files that crash, when I try to extrude some circles. Usually I get the 2D dxf file from my clients, I add in fusion a few 5mm circles and than model the 3D part, I noticed that when I select the circles I want to extrude, from time to time it crashes, I always send the error report (can I see all the reports I sent in my autodesk account somewhere ?) ... usually I work on lients dxf, but this time I worked on a simple design I created from scratch in fusion, I haven't imported any dxf.. but still fusion crashed, NOW I KNOW FOR SURE THAT THE CRASHES ARE NOT BECAUSE OF THE CRAPPY DXF FILES I RECEIVE FROM CLIENTS, but something wrong on fusion, mac version (those crashes on extruding circles never happen on windows)
This is a printscreen I made while fusion freezed, with the spining rainbow cursor, and while I wrote this message fusion still not recovered, I tried pressing escape but nothing happen, it still remained freezed.
Anyone else experienced this behaviour from time to time ?
UPDATE: a different view of my 3D Model, it's a very simple design, just a few circles mirrored. This time I forced stoped fusion and I haven't recovered any modification I made in the last 15 minutes. Usually when it crashes I get a recovery file, but this time probably because I forced quit the app after waiting about 10 minutes, it didn't create any recovery file.
RajkumarIlanchelian
@ovisopa Do you mind sending me a direct message of the email used to send the error reports? I can filter for them in the backend to see what could be happening?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@ovisopa Thank you sending in your email. I was able to pull the crash reports you have sent it. Although the crash code seems to be in different areas of each of the report most of them are pointing to graphics.
1. Can you check to see if you have all the available macOS updates on your machine?
2. If you go into Fusion - help - support and diagnostics- there should be a graphics diagnostics. Can you paste the info from there?
Autodesk Fusion
Join Fusion Insider
ovisopa
Thank you for reply, here is the graphics log file if it helps.
[GPU Information]
GPU Device: Apple M2 Pro
GPU RAM: 21845 MB
GPU Driver API: OpenGL Core Profile
[Graphics Effects Settings]
Use high-resolution graphics: On
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
