Create a back plate for the attached sketch
gpetti20
gpetti20
Guys, Is there a way to create a solid back plate for the attached sketch? Hopefully I do not have to go into this drawing and delete the inside features.
Thanks, Glenn
Accepted solutions (3)
jhackney1972
Sure, here is a 1/16 inch thick back plate "attached" to the emblem.  You can modify the model using the timeline.  Model attached.
John Hackney, Retired
gpetti20
Mr. Hackney, Thank you for this. I do want to create the back plate to match the  outer outline of the sketch rather than just having a square plate behind it. Is this easy to do?
jhackney1972
You need to be clear on what you truly want.  I posted a second try to satisfy your requirements.  Model is attached.
etfrench
Simply window select all of FiremenMaltesecrossV2 sketch and extrude with negative distance:
ETFrench
gpetti20
Sir, I apologies for my not explaining exactly what I needed. My terminology is not perfect on some of these things that I ask. All of your answers in the past have been perfect for my fixes.
Thank You again,
Glenn
gpetti20
Thank you Sir.
Glenn
