Crash and loss of work
jeffescott
Advisor Advisor
491 Vistas
6 Respuestas
Mensaje 1 de 7
jeffescott
So working along then the body changed from a solid to an outline....
Clicked back and forth on visibility in the browser...
The body cam back to a solid rather than an outline.
Then it switched back to an outline..... clicking back and forth did not help also tried apperance did not help
I was unable to get the extrude i was working on to recognize the body to cut it.
Then fusion crashed
crash report 701170836
So now what happens i have reopened the file (lost 3 hours of work yes should have saved more often)
But body remains as an outline
0 Me gusta
Soluciones aceptadas (2)
492 Vistas
6 Respuestas
Respuestas (6)
Mensaje 2 de 7
g-andresen
Solución aceptada
If you mean body 6, it is in the primary level, but it is hidden by body 11 in the "Nylon Base" component.
günther
0 Me gusta
Mensaje 3 de 7
jeffescott
im sorry guenther for some reason I dont get any sound so it is tough to follow...
I did manage to get body 19 to show but again only with outline....
I have made some updates so I will reattach the file
any idea why know sound???
0 Me gusta
Mensaje 4 de 7
jeffescott
finally found it some how the display had toggled to wire frame only????
Now I just hafta figure out why i don,t get sound on your video
0 Me gusta
Mensaje 5 de 7
g-andresen
Because there is none.
günther
0 Me gusta
Mensaje 6 de 7
g-andresen
Solución aceptada
I took another look at the situation.
Obviously, there is a priority for opacity control.
Here, the primary layer setting overrides the settings in the assemblies.
That means, if an opacity of 100% is set for the assembly, it will only take effect when the assembly is activated.
However, if the primary layer is active (all assemblies), the opacity setting of the primary layer will take effect.
I have not noticed this effect before.
günther
0 Me gusta
Mensaje 7 de 7
jeffescott
Ill work through this.  Thx alot for all your time
0 Me gusta
