I am creating a 3D Printer project that will larger than print surface. Instead of adding dovetails, I thought it would be easier to attach the pieces with nuts and bolts. I'd like to counterbore the screw head and then cut in the nut shape (captive nut?)... I created it with a counterbore hole and a polygon to create the effect. But, I can't copy the items and use in other places. Just on the same axis with a Pattern, that I know how to do. Is there a different method to do this ? I tried Insert Fastener but couldn't get the nut to "cut" through the body. So I don't know that was proper way of doing it. The way I did the hex nut cutout was extruded it with 2 sides. bottom side went to end of bottom cube (40mm) and the top was down to 36mm leaving a 4 mm cutout of the nut. Would this have been the proper way or is there a better way to do that or just a better way to do what I am trying to do? I've these here, then I would like to do the same on different axis to connect all the pieces together.
