Automagic Constraint has strange behaviour - bug?
Hi All,
Banging out another tutorial to learn new stuff and noticed something a bit strange.
I am drawing a sketch line on the XY plane from the Origin that is 0.8" long at 130 degrees.
When I finish the line I get an automagically created construction line with a horizontal constraint and an
unconstrained point and the line I just created. This unconstrained point can only move along the X axis because of
the horizontal constraint.
My confusion comes about because fusion wants me to put a distance dimension on this point from the Origin in
order to fully constrain the sketch. I was expecting to have to draw my own construction line and make this point
co-incident to lock it to the quadrant I want so that the angle was not floating in space. What I don't understand is
that if fusion is smart enough to guess that my angle was in relation to the X axis, draw a construction line and put
a horizontal constraint on it then why does it A) need a point or B) if it needs a point to internally convince itself
this is in relation to the input angle why does this point it created have to have a distance dimension on it?
d17 is the dimension I just created for the line I DO want.
I don't see why I need to dimension this line fusion created. It would make sense if I created the construction line.
Fusion was smart enough to work out the angle was in relation to the X axis and create a horizontal construction line
so why does it need further input? The length of a construction line is irrelevant.
Cheers
Andrew
