Counterbore dimension in Fusion 360
cbales
cbales
How do I create a diameter dimension exactly as shown in the image? While I can insert all the necessary symbols into the dimension, I am unable to create multiple lines with the diameter dimension.cbore dimension.PNG
Beyondforce
Hi @cbales,
Will you please create a screencast and show us what you are doing and the results you are expecting!
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
daniel_lyall
Have a look on NYCCNC youtube channel he did a vid and showed how to add the callouts it was about 5 weeks ago, of the top of my head it was edit it after you add the dimensions.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
cbales
Screencast uploaded.  In the screencast you will see me adding a diameter dimension and then attempting to create a multiline counterbore hole dimension with cbore diameter and depth.  The symbols can be added easily but everytime I attempt to hit ENTER to go to a new line it ends the DIMENSION EDIT command.
Beyondforce
Unfortunately, I'm not a Drawing expert. Maybe @jeff_strater could help.
Ben Korez
| YouTube
daniel_lyall
When you are ready for the next line it's shift then enter, most times in fusion if you can do something you normally can do with A key and it wont work, it may need shift or ctrl first.
There are a lot of commands in fusion that use shift and ctrl.
Daniel Lyall
The Big Boss
Mach3 User
cbales
Excellent! Works perfectly.  Thanks.
