- Mute
- Permalink
- Report
Hi all...some questions on sketching (see attached picture of some bolts going through a plate):
-I created a sketch with all of the geometry I needed
-The base plate needs to stay the same place
-the bolt housing needs to rotate by 12 degrees upwards
....If those were separate bodies, I would be able to do that easily, but they are not...everything was created in the same sketch.
Questions:
-I cannot see how to copy a sketch into a new sketch (then I would be able to save all of my original work, and delete the parts I don't need out of the new sketch and make bodies just out of the bolt housings
-Or, I cannot see how to select specific parts of the geometry (that originate from a single sketch) and make new bodies out of them. In this way, I would select all of the bolt housing pieces and click "make new body of of these pieces" and then be able to rotate them
...because right now, when I select Move-->rotate, everything wants to be the target of the Move command.
Ideas?
Thanks!
Nick Kloski
