Copy / Paste in Drawings
bui.tung.duong
bui.tung.duong
Hi there,
I work in outdoor furniture company and are making trial use in my company. We are going to buy license.
We have trouble when making sheet ( Work instruction) which has same some hardware and components that We cannot copy/paste them to another sheet(or in the same sheet).
Is there other way to do that work quickly instead of inserting the base view again ?
Here is some image( with some basic product in my company)
We have to make Assembly instruction also. This is the PDF file.
ClintBrown3D
Hi @bui.tung.duong
Currently, it is not possible. You will need to create a new base view.
But the good news, is that we are working on a project that will allow you to duplicate sheets, this will re-create a copy of the existing sheet, will all the views and dimensions. Check out the public roadmap here: https://bit.ly/2DRoadMapFusion
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
bui.tung.duong
Thank a lot @ClintBrown3D
bkmtech
Thank you for your reply.
I am going to stop using Fusion.
