- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working on a flat panel and need to add text for laser engraving. Working in Sketch mode I can add a text block and set the parameters for the text needed (Arial Rounded MT Bold, Text Height 0.200 inch). This is a simple process. The next time I add a text box, all the parameters return to default, I have to set everything again. In addition, if I use the "rectangular pattern" duplicate command on the text boxes all that duplicates is the box, no text or settings. Since I am placing the same text multiple times on my panel I would like to use the "rectangular pattern" tool instead of placing new boxes for each and every line of text.
Questions:
1. How/where do I set the "default" setting for new text boxes?
2. Is there a way to Copy/Paste or duplicate text boxes when working in Sketch?
