Copy extrusion into a component
I have created a cylinder model with a extruded area, I want to copy the extrusion into its on body or component since I plan to assemble these together... how would I go about doing this?
HughesTooling
If I've understood what you want, create another component and activate it then select extrude and make sure Operation is set to New Body.
And you should get a separate body.
Mark Hughes
Owner, Hughes Tooling
