Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
coolinear fails to align sketch line with projected line
2 REPLIES 2
fsonnichsen
155 Views, 2 Replies
It is a little hard to capture this so I am sending a png with the fdm.  I simply want to make the lines on the opened sketch (in blue) colinear with the lines in the projected (grey) object. I click on a line in each item and click on colinear and it raises the "cannot solve" condition. Perhaps I am being presumptuous to assume I can align a sketch with a projected object?
   Before I head for my cosine table I would like to see if there is a "nice" way to do this-
Fritz
2 REPLIES 2
laughingcreek
in reply to: fsonnichsen
I don't think you have the lines projected in in the model you provided-
but I guess you mean these-
the angle of the projected lines doesn't match the dimensioned angle, so there's so way to make the lines co-linear unless you delete the angle dimension, as in the sketch above
fsonnichsen
OK--I removed the angle constraints from the upper piece and then collinear worked as you indicated. I have the precision of my dimensions set too low. I increase the precision and found that they deferred from 76 deg by a VERY small amount.
thanks!
Fritz
Technology Administrators
