I am working on recreating history for an existing model imported as a STEP file. I have the following hole in the model.
I would like to add a taper to the edge (say, 30 degrees) to achieve the following result (the result adds an 0.5mm filet after the taper, which I will want to add after).
How can I achieve this? I feel as if the chamfer tool would be correct to use here, but I have not been able to successfully get it to do anything, it seems to always fail. I do not want to use a tapered extrusion for this. I've attached the project below. Thank you.
