Most of the time it works and I do it as follows: Insert mesh -> Generate Face Groups(Type: Accurate) -> Convert Mesh(Operation: parametric. Method: Prismatic) . After converting mesh it has holes and completely missing faces. I also get an error - "Compute failed. Not all facegroups of the mesh body could be converted. The generated solid or surface body is not complete."
The mesh doesn't have too many faces or triangles. I'm pretty new to this and this is the only way I know how to convert meshes into solids. All other times it has worked.
In the warning message it also states "Try a different method for conversion or adjust the face groups to correspond better to geometric features of the mesh."
Are there any mistakes I'm making during this process or another step I should be doing? What other methods can I use and/or how do I adjust the face groups like the warning suggests?
Screenshots are 1. After inserting mesh with properties shown, 2. The mesh after being converted.
The .f3d is also attached.
