Convert upload igs file to Solid
sajjapongse
sajjapongse
Hello.
Right now I import cad from manufacture and want to convert (igs format) them in to solid for mass measurement.
Can I convert it in Fusion 360 or I need to create said cad file from scratch?
Thank you.
jodom4
Hey sajjapongse,
I think the Patch workspace is probably the solution to your problem. Here's a solved thread on the subject: https://forums.autodesk.com/t5/fusion-360-design-validate/impost-igs-as-solid-model/td-p/5983539
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
TheCADWhisperer
If you have trouble figuring it out - can you zip and attach your original *.igs file here?
sajjapongse
Thank you very much.
The problem is solve now.
sajjapongse
Thank you.
