Convert mesh to solid in free version…
Message 1 of 20
So it was nice and simple to convert to brep then remove or combine facets in older versions. Now i cant convert my .obj mesh so easy and they want me to pay for this feature. Im not a very avid user of the program and i only use it to modify 3d print files and build random things for around the house. It really dont make sense for me to pay the high price for the full program for what little i use it for.
is there a work around i can do to take a mesh and convert it into a solid without facets?
Replies (19)
Message 2 of 20
g-andresen
1. Remove the facets.
2. The option to convert a mesh into a clean solid did not exist until the August update with its independent mesh register.
günther
Message 3 of 20
It does not remove facets. Delete just removes the whole face. Unless im missing something
Message 4 of 20
g-andresen
what I mean
1. Convert mesh to Brep
2. Delete faces in Solid mode
günther
Message 5 of 20
1. import .obj
2. Convert mesh under mesh drop down
3. delete facets in solid mode
4. Facets dont delete but the face delete
5. have no clue where to go from there..
it used to be as simple as right click on mesh object in list click covert to brep go to solids delete individual facets and view and edit solid object.
anyone else have any recommendations?
Message 6 of 20
TheCADWhisperer
Message 7 of 20
HughesTooling
Which workspace are you in? Just did a test and it works as before if you're in the Solid or Mesh workspace, in the surface workspace it will just delete faces and not merge/heal (it has always worked like this in the surface workspace).
Mark Hughes
Owner, Hughes Tooling
Message 8 of 20
HughesTooling
One more thought, did the conversion create a solid body (white cylinder in the browser) of an open body (orange)? Open bodies will not heal if you delete a face.
Mark Hughes
Message 9 of 20
So the confusion is real right now i may have to attach a video. But yes that’s exactly what im talking about being able to do. But it legit deletes the face completely or does nothing. Is there a setting maybe that is off preventing this?
Message 10 of 20
so here is the error i get when trying to remove facets
Error: The selected faces could not be deleted.
Ensure that faces are only selected from a single body, and that no duplicate or invalid geometry is included in the selection.
Message 11 of 20
hey here is the file im trying to delete the facets on. file is so large i had to split it into two rar files
Message 12 of 20
TrippyLighting
Please do not attach .rar files. .zip will do.
Message 13 of 20
Apologies, i will use zip. Tonight i will attempt this again. But for some reason its selecting the face and not facet.
I will attempt to make a video showing my steps. But the way its acting i feel like theres a setting or something i am missing. 🤔
Message 14 of 20
TrippyLighting
You are using the wrong software tool for the task!
Message 15 of 20
TrippyLighting
Oops. Wrong thread (at least for now)
Message 16 of 20
https://www.youtube.com/watch?v=bYYQDPljPa0
ok my fellow 360 users!! I made a video my but editing skills stink so unfortunately i didnt cut wait times. but i go through the process of what im attempting to do. if you see im doing a step wrong or im missing a step please let me know!
Message 17 of 20
TrippyLighting
That was unneeded. Instead, you should have attached the original .stl file in zipped format.
We know what you are trying to do!
I don't think that most of the geometry is suitable to do that. What Fusion 360 does when converting a faceted, but seemingly flat surface into a single surface is, it looks for coplanarity within a given, internal tolerance.
It also needs "sharp" edges so it can determine the surface boundary.
The mesh structure of this object looks like it was originally modeled with a Sub-D modeler and as such has many areas that don't meet the coplanarity and boundary criteria.
Again, attach the original model zipped in original format. Then I can see what can be done.
Message 18 of 20
here are the .obj files that im trying to work with.
Message 19 of 20
TrippyLighting
I looked at the models In Blender and this geometry/mesh is not suitable for conversion into BRep geometry for several reasons.
With a good bit of manual clean-up the prismatic parts could be modified to get some of this converted into a T-Spline and then BRep/NURBS, but there are some parts of these meshes that I believe have been created with some cloth simulation that lack the usual Sub-D quad based structure. Those will have to be separated from the main object and then re-meshed into a quad structure.
There is not much in Fusion 360 you can do with this.
Message 20 of 20
Thanks! I will have to try and figure out a work around then. I appreciate the help from everyone! Great program and great community.
