Convert from TS to Brep failes
When convert this to Brep i failes. The message is: The operation failed  due to a self-intersecting  surface. Try adjusting  the values or changing the input geometry.
When i look at the model in box mode, there are not any intersecting edges. Everything look fine.
Does any one have an idea?
TrippyLighting
Can you post the model ?
Export as .f3d and attach to your next post.
Of course. Have you an idea of what may be wrong?
jeff_strater
Hi @Anonymous,
I took a quick look at the model.  I admit that I am confused as well.  The area where the supposed self-intersection occurs is shown in the error:
Usually, I can find these pretty easily by switching to Box display, and often you can see that the control frame looks bad, but in this case I can't see anything obviously wrong:
No overlapping edges, etc.
Even Repair Body doesn't fix it.  I'm going to have to send this one to the TSpline guys to take a look.  Maybe there is an obvious fix, maybe there is a bug.
Jeff
Jeff Strater
Engineering Director
jeff_strater
Hi @Anonymous,
One of our team members showed me how to fix this.  However, I have no idea why this fixes it or what the underlying problem really is.  Still investigating...
Jeff
Jeff Strater
