Convert a Curved body that is made up of multiple sections into a solid body?
glennd789
Message 1 of 11
glennd789
I am learning Fusion and I am stuck on a small issue.
I have a curved surface that is made of multiple small curved and flat sections I would like to combine them into one continuous solid curved edge.
How can I achieve this?
Replies (10)
Message 2 of 11
davebYYPCU
Looks like an imported sketch result, (could be wrong)
replace it with a native Fusion sketch, that won’t do that.
Fix yellow timeline icons, with Undo command as soon as they show up.
Might help.....
Message 3 of 11
glennd789
Thank you for the reply.
Is there any way to patch it or project it into a native part or would It be best just to have to start over?
Message 4 of 11
aliobidi
Hi ,
attach your file
Message 5 of 11
glennd789
Let me know if this is the correct format.
Message 6 of 11
jhackney1972
It will all Stitch together.  Here is your file as one body.
John Hackney, Retired
Message 7 of 11
glennd789
I was able to stitch it but I was trying to get it to combine into one face, so I could achieve a more uniform and organic surface and also enable me the ability to emboss the outer face with lettering.
Message 8 of 11
aliobidi
your sketch must be as a one single line
I made this body to understand what I do in timeline
just see the timeline and ask me if you have a question
your file below
Message 9 of 11
glennd789
Ok, I follow the workflow.
Did you just select the face and extruded a new body to achieve the body you made?
And then you just dragged, dropped, and combined the new bodies to make them one?
Thank you for your help.
Message 10 of 11
aliobidi
yes for both , but on other side for better work you should start a new sketch from a zero (as one single sketch line ) because what I do is a sample .
Do not forget to mark the Forum post, that solved your question, by selecting the "Accept Solution" icon. This closes the question, makes the solution available to others with similar questions and acknowledges the solution as helpful.
Message 11 of 11
glennd789
Thank you for the help
