Lofting splines
Lofting splines
mateuszFZ8LU
Lofting splines
mateuszFZ8LU
I am trying to recreate a car badge (photo attached) in Fusion 360. I am trying to use the loft feature, but I encounter a bad geometry/self-intersection error. I could create rails, but I have a different number of spline control points between the two sketch profiles, not to mention it would take me quite a lot of time.
Can someone point me in the direction of how to go about solving this issue or show me a better method to recreate the badge?
Thanks in advance
dsouzasujay
Hi @mateuszFZ8LU
If you know the Font follow this
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
mateuszFZ8LU
Unfortunately, I could not find the exact font, hence why I used splines.
I did think of using an extrude with a taper angle. However, the taper angle on the real badge is not consistent (the top layer of text is offset), so I had to create two sketches.
mateuszFZ8LU
I have created two rails now using 3d sketch
However, I am finding that the effect in some areas is undesirable (curvy and not straight taper)
davebYYPCU
Use surface Loft, for the taper / curved walls, if curved you will need rails.
Edit, for straight taper, surface sweep, Path with Guide rail, > full extents
Might help....
jeff_strater
@mateuszFZ8LU - can you share the most recent attempt?  This image almost looks as if you are using "direction" as a takeoff condition on those profiles.  Or, it could be that you just need more guide rails.
Jeff Strater
Engineering Director
