conversione corpo in lamiera
mattiamandello
mattiamandello
Community Visitor
Community Visitor
Salve a tutti, volevo chiedere se qualcuno può aiutarmi in quanto non riesco a convertire il componente in allegato in lamiera.
grazie in anticipo.
laughingcreek
double curvature. this object won't convert to a fusion sheetmetal body.
Warmingup1953
As Laughingcreek has noted, Fusion can't create a flat pattern, but Meshmixer can with some qualifications regarding accuracy. The surface areas are very close once I scaled the Meshmixer-created .svg so as give a 24 mm edge length.
