Control number of holes in a sheet based on sheet size but keep holes cc??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have used parameters sometimes and actually got it to work great but most often something messes with it and making the whole design shape-shift when trying to change a value.
So I am asking for assistance this time ๐
I am making a welding table design and I want to be able to change its size easily.
The table is going to be made of sheet metal that I laser cut and the weld together.
I could make it solid in one size but I really think I will have requests from the welders in the shop to change the size to fit the table in some small corner.. ๐
Main parts are: The table top with hole pattern, side panels with hole patterns and supports inside.
Here is a example of a table made this way.
https://www.texasmetalworks.com/product/fully-fabricated-welding-table/
Here is how far I am right now. I made the parameters for the table top and at the moment im stuck at my hole pattern (pCnt). I want to always have a certain c-c measurement between the holes (50 or 100 mm), so I guess I need a couple of fixed sizes depending on that. Or if its possible to lock that parameter to only make these holes when there is room for it.
I started measuring out my first hole in the origo corner of my sheet and really making sure that first hole has correct dimensions and this locks it in to place I guess.
In the image below (that dont have correct c-c between the holes) I focused on getting both end holes at the same distance from the edges. (-wdt + dia * 3)
I could use "Spacing" instead and set it to 100 mm to instead adjust the quantity to the width and depths of the table?.. In the other image below I have set pCnt to the value of 1 and then just multiplied it 5 times. Here I guess I need a formula based on table top size to determent number of holes..
And this is just the top. I need the sides in this equation as well. And the holes is not the only feuture that needs to be a pattern that adjusts. I need the tabs and "dog bone holes" for manufacturing also. ๐
Anyone who feels this is a walk in the park?. Feel free to hand out some "this is how you should do it!" ๐
thx
parameters
spacing
EDIT*
I made the width and height "400 mm + dia * 3" and this fits the 5 holes in both directions (pCnt * 5).
How can I make the pattern count (pCnt) change the number of holes if I want to make the table 2000 mm wide and 1000 deep for example?
400 mm + dia * 3
