Constraints to an Imported SVG?
I was wondering if I can apply (sketch) "constraints" to an imported SVG file?
Every time I try I get an error. I can extrude, but it will not let me edit anything on the sketch.
HughesTooling
You need to unfix the SVG sketch, open the sketch for editing and window select all the curves then click unfix on the sketch palette.
Mark
Mark Hughes
Owner, Hughes Tooling
michallach81
Yes, you can, just don't forget to unfix your svg (change green lines in to blue, I had to do that twice):
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
