Use of FUSION 360 in a network
I belong to a secondary school, we actually work with fusion 360 but we have had to install them using a virtual box due to the following: FUSION 360 only allows its use to the user that installed it and as it is the network administrator the responsible for installing the software the users can not use it.
Work with a virtual machine causes lot of problems and slows down the software a lot.
Is there any way of avoiding it in such a way that the users can use it directly without the virtual box?
Thanks in advance.
innovatenate
Autodesk Support
Autodesk Support
I believe the below link may help. There is a different installation designed for a computer lab.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Let us know if you have any questions.
Nathan Chandler
Principal Specialist
innovatenate
Autodesk Support
Autodesk Support
I hope that linked helped! Let us know if you bumped into any issues!
Nathan Chandler
