Constraining a loft to be perpendicular to a sketch
doodooronron
doodooronron
I have a loft between two different diameter circles, but when I mirror it around the larger circular face (Profile 2), there is not a smooth transition between the mirrored bodies. Is there a quick and easy way to force the transition to be perpendicular to Profile 2?
I'd be grateful for any suggestions.
laughingcreek
you can try changing the continuity condition of the profile to direction-
but I suspect you still won't be happy with the results
laughingcreek
maybe the attached is what you after?
doodooronron
Ah, I missed that control. That could well do the job. I'll check it out.
doodooronron
Yes, that's exactly what I was after.
Since posting my question, I had a good think about the problem and realised that the neater solution would have been to not mirror half of the component, but to add a second small circle on the other side and loft the three sketches, which I think is what you did.
I had just finished doing that when I saw your reply.
Thank you very much for going to all that trouble to solve my problem.
My result:
laughingcreek
@doodooronron wrote:
... and loft the three sketches, which I think is what you did.
nope.  you should probably have a look at what I did.  it's much simpler.
doodooronron
Yes, it is different and looks simpler, except it's not clear to me what you did in sketch 1.
It looks like a path that is a sweep of points on a line that rotates as it gets shorter, but this newbie hasn't come across it before.
There's a lot to learn........
