- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I created a simple rectangle sketch and extruded it. I then created a "midplane" that was down the center of the rectangle body. I then attempted to create a "center rectangle" sketch with the center point constrained to the plane - but- apparently in F360 you can't align sketch geometry to reference geometry. After goign through a bunch of the forums, I tried creating a projection of the plane into the sketch, this worked and constrained the sketch geometry, but when I went to create a cut extrude, the projection line had bisected my rectangle sketch in two. I was able to select both halves of the rectangle, but when I created the extrude cut, while all of the existing geometry wsa removed, some sort of phantom planar surface remained at the bottom of the extrude cut.
I've attached a screenshot.
This seems like an increadibly rudimentary task - so I'm hoping I missed something . . .
