Constrain a sketch to another sketch
JamellMoore
Message 1 of 10
JamellMoore
At some point I have seemed to have lost the the ability to constrain sketch entities from one sketch to another. Is it still possible?
In my current project the constraints that I had made are still there but if I delete the constraints and try to reapply them its not possible. I am only able to constrain to entities within the activated sketch.
Replies (9)
Message 2 of 10
PhilProcarioJr
@JamellMoore
My first guess would be that your preferences got changed somehow. There is a setting for automatically creating projections.
Can you project the sketch geometry from one to the other then add constraints?
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 10
JamellMoore
Thanks for your reply. Yes I am able to project the from one sketch into
another then apply the constraints. I hadn't thought of that because
haven't used Fusion that much and didn't realise that was how it worked. I
can now see that the magenta coloured lines are the automatically projected
lines.
I am assuming this is a bug because all of the options relating to auto
projections are checked within my preferences. Or could there be another
reason?
Message 4 of 10
PhilProcarioJr
@JamellMoore
There could be other reasons, but I would need to see the problem file to figure out why it is not working.
Phil Procario Jr.
Message 5 of 10
JamellMoore
Instead of uploading the design file I have a created a screen cast of me trying to constrain two rectangles in a blank project and file.
Message 6 of 10
PhilProcarioJr
@JamellMoore
This looks like a bug.
@innovatenate can you check and see if this is logged?
Phil Procario Jr.
Message 7 of 10
JamieGilchrist
hi jamellRNYCJ,
i've sent this on to our development team to take a look at the behavior.  As PhlP, suggests this is likely a bug, but we want to make sure.  will keep you posted about what we find out.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Message 8 of 10
JamellMoore
Ok, Thank you both. Atleast I can manually project for now.
Message 9 of 10
jakefowler
@JamellMoore - Just to confirm, this has been logged as a bug, our development team are looking into it now. Very sorry for the inconvenience this causes in the meantime.
Jake
Jake Fowler
Fusion 360
Message 10 of 10
JamellMoore
I have just seen this issue has now been resolved in the May 30, 2017 Update. I have tested it and can confirm it's working my end.
Thanks to all that help sort this.
Jamell
