Data managment & projects - how to best transfer a folder
I've made a clear newbie error in starting a model within an incorrect project. Now, that I've discovered that, I want to "extract" this part and make it into a separate project. What is the best way of doing so?
In detail: I have a "Project HPI" which contains three folders  (with subfolders each) and a model. One of these folders (3D P) contains my second project. No linkage exists from this folder outward or from anywhere else into this folder, but several linked files reside inside this folder's substructure.
Essentially, I want to completely remove this folder from "Project HPI" and create a new "Project 3D P" which then contains this folder and all content.
Is there a convenient way to achieve this?
HughesTooling
If you go to your online desktop you have the option there to move folders, you will not be able to move to another project if there are any linked designs in the folder.
Mark Hughes
Owner, Hughes Tooling
Thanks! I was totally unaware of the online desktop Smiley Embarassed
