Constrain a Center Point Rectangle
I seem to be doing something wrong. I want to draw a rectangle and I want it to be fully constrained. Simple, so…
I click Sketch, Rectangle, Center Rectangle.
I click the top plane to start the sketch.
I click the origin and drag my rectangle to size.
I click Sketch, Sketch Dimension.
I click a long leg of my rectangle and enter a dimension.
I click a short leg of my rectangle and enter a dimension.
Should I not have a fully constrained rectangle? I don’t, or at least it is not all black as I would expect it to be if it were fully constrained. I see the horizontal, coincident, parallel, and perpendicular constraints…everything that should constitute a fully constrained rectangle, yet the rectangle is still blue. I cannot figure out what is not constrained but I am not comfortable moving on without fully constrained geometry.
I checked and I have “Sketch – Color sketch geometry based on constrain status” selected.
Is my geometry fully constrained and Fusion just isn’t coloring it correctly or is my geometry under constrained and I need to keep digging? Is there a reliable way to know for sure?
