Connecting faces of different sketches to create a curved triangle pyramid
Note: i dont know if there are similar questions of this because i dont know how to word this question at all.
Note: This is also not the same as the topic "Pyramid with curved sides"
So i want to connect these faces to create a body. What i want in the end is somewhat of a triangle pyramid made out of those 3 faces. However, these aren't triangles, because the faces are made out of lines with conic curves of 0.75 rho value.
Those highlighted faces will eventually make a "triangle pyramid" but with an increasing base lengthThose highlighted faces will eventually make a "triangle pyramid" but with an increasing base length
Accepted solutions (4)
TheCADWhisperer
Does Loft to Point (with guide curves) work?
Can you File>Export and then Attach your *.f3d file here?
lichtzeichenanlage
Nice design. Next time you might want to reduce your sketch effort and just implement one spike and than pattern it. Just a thought...
Thanks for the reply!
No, i tried loft and it doesnt work. I didnt expect loft to go to a specific point lol. Anyways, here is what happens:
Without guide rails:
With attempted guide rails:
gsdrgdrhtrhjrtjnh.JPGNOTE THE SAME
THING HAPPENS WHEN I TRY TO SWEEP IT UP AND USE GUIDE RAILS
What if i try connecting the curved lines to create faces? then i can do boundary fill. But then the lines are on different sketches and different planes....
TheCADWhisperer
Why did you mark it as Solved if it isn't solved?
You have all sorts of issues in your Timeline.
File>Export and then Attach your *.f3d file here and end all doubt.
lichtzeichenanlage
Can you share the design? Perhaps you might be able to use loft + rails
