Connecting faces of different sketches to create a curved triangle pyramid
Note: i dont know if there are similar questions of this because i dont know how to word this question at all.
Note: This is also not the same as the topic "Pyramid with curved sides"
So i want to connect these faces to create a body. What i want in the end is somewhat of a triangle pyramid made out of those 3 faces. However, these aren't triangles, because the faces are made out of lines with conic curves of 0.75 rho value.
Those highlighted faces will eventually make a "triangle pyramid" but with an increasing base lengthThose highlighted faces will eventually make a "triangle pyramid" but with an increasing base length
lichtzeichenanlage
Switch to the Patch workspace and try Create -> Patch or Create -> Loft. If all faces are created Modify -> Stich them together or Create -> Thicken them.
