第 1 条消息(共 19 条)
I am designing some trailing arm brackets with the help of a 3d scan mesh. The goal is to cut the brackets with cnc plasma and bend to shape. The brackets have two sheet metal faces at different angles that need to be joined. I have tried lofted flange in sheet metal, and Loft in solids with no success. The Loft function in solids worked to connect the two pieces of sheet metal but it wont allow me to create a flat pattern. The picture shows the angle differences and where they need to meet. Any help is greatly appreciated. Thank you
已解决! 转到解答。
