Confusion with open command?
ronydee
Message 1 of 13
ronydee
Question when Selecting File->open:
1. Do I have the ability to cleanup the projects and files to be more organized on the hub?  I did not realize the fusion web client is not the same view of these files on the hub.
2. Within the project, there  is the comments.  Where do the posts reside?  Another assumption on my part was thinking the post is saved with the project when saved.
Replies (12)
Message 2 of 13
jhackney1972
You have to ability to create New Folders, Move and Copy within the Fusion Web Database.  You can likewise delete Files, Folders and even Projects using the Archive command.
Forum posts are not saved to your Web Database.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
Message 3 of 13
ronydee
@jhackney1972 I have the education license so may not be exactly what you have?  There is a Home button (pic 1)  that shows al the folders and files (pic2) that i can perform operations on.
Message 4 of 13
jhackney1972
Fusion Educational License has all the features of a Fusion Subscription License which I am using.  You are looking in the wrong place.  Open your Data Panel and look for the icon I indicate below.
Message 5 of 13
ronydee
@jhackney1972
aaah I see have to select a drill down into my project.
When I click on the web icon, the Fusion Web Client only display this info:
Also reading about ways to launch Fusion Web Client in different ways still displays the image above.
Message 6 of 13
jhackney1972
I have no idea what "FTM" is?  Try another method, enter this address in your favorite Web Browser.  Once there, log in using your Autodesk ID and Password.  This is the same you use to log into Fusion.
Message 7 of 13
ronydee
Hmmm viewing that location does not match my data panel.
I'm wondering if I have missed a step when creating my projects shown in the data panel to be incorporated into your mentioned location?
I will create another post asking about the FTM site when clicking on the web in the data panel.
Message 8 of 13
jhackney1972
Of course the website I gave you does not look like the Data Panel, it is the Web Database.  It DOES contain all your Projects, Folders and Files.  Do a little exploration in it and you will see all.  Start by Left Clicking on the word Fusion in the top left corner and you will see all your projects.
Message 9 of 13
ronydee
@jhackney1972 Hi, same results clicking on the Fusion icon.   Does not at all reflect the data panel. Folders/files are not in the data panel view
So what is the connection between the data panel view (Web database) and the Fusion Web Client View. Is the Hub the answer? I've read all the documentation about the roles/breakdown of projects and hubs.
Sorry for beating this issue into the ground and being patient yourself.
Message 10 of 13
jhackney1972
I will take one last stab at this.  I will do this with a video showing the relationship between the Fusion Data Panel and the Web Database.
(view in My Videos)
Message 11 of 13
ronydee
@jhackney1972 Hi again
Thank you again for taking time on this subject.
the result is the same as discussed about clicking on "open the web" icon.  The link displays the FTM display
Looking at the link not sure if this is what you see as your link which would be with a  different ID:
https://myuri367.autodesk360.com/login.....
Gotta be something not setup properlywith my Identifier in the link.
you have spend enough time helping me with this.  I will accept the solution since it is the correct method to view the web database.
Message 12 of 13
etfrench
Are  you on a team hub as well as individual? Which one are you signed into?
ETFrench
Message 13 of 13
ronydee
@etfrench @jhackney1972
Well this is embarassing.  I signed out, and apparently i have 2 logins. -
Acct1:  is how i was able to get  fusion  for education use
Acct2:  my personal gmail acct (Not sure why that is).
SO logging in using Acct2 works as expected as @jhackney1972 pulled his hair out for me.
But I have been creating my projects under my Acct1, so that's why I'm not getting to the web database but FTM.  What's the difference between these 2 accounts that allows me to get to the web database and not being able to do so on the other acct?
