Conforming a 3d object to another 3d surface.
Message 1 of 27
Hello.
I want to make a flat rectangle that has been corrugated into a 3D wave pattern and then I want to have another flat rectangle that has a more complex corrugated pattern applied to it and I want the more complex pattern to be merged into the first pattern but I want the complex pattern to "ride" the contours of the waves on the first pattern.
Is there a method of making the second pattern merge with and conform to the "waves" of the first pattern?
The geometry would be very difficult to make from scratch so I'm hoping I could just make both patterns individually before merging them.
Thanks.
Replies (26)
Message 2 of 27
YoavFriedlander
It would be great if you make a hand sketch even of your intention. But I would say you could probably make the corrugated patern using a sheet metal extrusion unfold the pattern and then create a sub patern! that can be really crazy - I would love to see a sketch of what you intend to make it will make it much easier to come up with a plan 🙂
Message 3 of 27
Sorry I'll make myself more clear.
I want to imprint this pattern
tx5hDoW
onto this pattern
IoanJId
and I want the first pattern to follow the contours of the second pattern.
Message 4 of 27
I'd also like to place both patterns onto a cylinder and have them follow the contour of the cylinder so the cylinder is embossed with the patterns.
Message 5 of 27
YoavFriedlander
You can use the new emboss tool! there is a great video I'll try to find it - showing how to make a knurled pattern using the emboss tool + here is a quick try using the sheet metal but it is not as perpendicular
Message 6 of 27
YoavFriedlander
The difficulty will be the calculation to make something appear as waves on waves take a look:
Message 7 of 27
jhackney1972
My model is not "formed" but constructed with a little math to get the angles right.  I left the cylinder and the layers of the pattern as separate bodies.  You can combine them into one unit using the combine command if desired.  You can follow the time line to see how it is done.  Model is attached.
John Hackney, Retired
Message 8 of 27
jhackney1972
I forgot the screen capture of the model.  Here it is.  You can download it from my previous post.
Message 9 of 27
I'm having a difficult time figuring out how you did the proper angling and copy pasting of the wave protrusions against the cylinder.
Message 10 of 27
TrippyLighting
I am watching with interest how this develops.
What @YoavFriedlander ran into is that the surface pattern distorts. It is stretched on top of the waves and as it travels down into The valley it is compressed. That will be difficult to eliminate. It might visually be less obvious if the surface pattern is a lot smaller (higher in frequency, lower in amplitude) than the wave surface it is supposed to follow.
Message 11 of 27
YoavFriedlander
@TrippyLighting yes - I am still trying to figure out if such symmetry can exist - I bet there is a way and my brain can't overcome the obstacle - something about the above cylinder in previous comment by @jhackney1972 gives me hope but I suspect that the problem will start in the transition between outer facing curve and inner facing curve. I made a more elaborate demonstration of the problem you mentioned previously via the Sheet metal environment:
Message 12 of 27
YoavFriedlander
Here is a progress based on @jhackney1972 cylinder
The main issue that if I start with a circle divided to 36 sections and create 36 tangent circles around it the inner circle creates an angle of 12.1 degrees vs. 10deg on the outside which means it looks nice but it is not symmetric!:) I think my next step is to figure out the circle that connects the center of all circles! maybe there will be a solve to the tension ?
It looks nice - but it is not absolute   correct
Message 13 of 27
YoavFriedlander
Also I realize it is better to use uneven number of circles ! which even makes life harder 😕
Message 14 of 27
jhackney1972
Take a look at the Screencast.  The angle for the original sketch is 360 degrees divided by the number of instances in my circular pattern.
Message 15 of 27
jhackney1972
I would really enjoy getting into some of your models to see what you are thinking and creating but you have a habit or posting screen captures but no attached models.  I am sure the original post would like to see your models attempts also.
Message 16 of 27
YoavFriedlander
@jhackney1972 do you think you can find a way to do this process with even half circles going in the wave form? Your method is way more clean than what I attempted doing!
Message 17 of 27
YoavFriedlander
@jhackney1972  I am sorry for that! I didn't want to spam with things that I wasn't sure answered the question but you are correct - I should do more screencasts and share F3D files - here is the one from the latest screenshots:
Message 18 of 27
jhackney1972
Here is the same pattern created on a sheet metal curve.  It will unfold and refold using the timeline and it will even create a flat pattern with a big red box in the timeline.  Plus it is a pain to do since you must use Extrude - Join for each row which means you have to duplicate your pattern sketch over and over.  Model attached.
Message 19 of 27
I've been trying to do what jhackney1972 did but I continuously fail.
I'm trying to get the waves to be 0.5mm in height, length, and width and I want them in rows of 40 on a 4 inch cylinder but I can never get the waves to line up properly.
Clearly my math is failing me somewhere.
DZWz3uD
There is a gap between each one and I'm a bit clueless on where I went wrong.
Message 20 of 27
jhackney1972
The dimensions you give do not seem correct.  A 0.5 mm sketch is an extremely small sketch plus you are mixing units when you say your cylinder is 4 in, diameter or radius you did not say,  The measure shown in your screen capture is 13.21 diameter which does not match anything.  In the sketch below, which is one segment of my model, note the bounding lines go to center.  I also originally dimensioned the curves at 1" to originally get a general size but then removed it to let the segment angle control their size.  All the curves have an equal constraint applied.  The construction circle is just a floating guide circle for the curve centers.  The angle of the segment is the number of my, later to be applied, circular pattern of 21 divided into 360.  If you attach your model, the forum users can help you out for sure.
