Configured Design - Sketch - Unexpected behavior
Christoph_360
Christoph_360
Hello
When switching from the Configuration Large to Small, the end point of the line loses reference to the arc.
Does anyone have an explanation for this behavior?
Christoph
gautham_kattethota
Hi @Christoph_360
I would have expected the straight line to map to the same curve end points as you switch between configurations.  Probably the constraints on it could not be met and it moved.  But its not right for the line to loose its end point references.  We need to take a look at it.  For some reason Fusion is not able to open the attachment.  Could you export and attach it again.
Gautham
Gautham Kattethota
Software Development
Christoph_360
Hello
At the moment my laptop is having problems.
Christoph
Christoph_360
Hello
I downloaded the Zip-file from the Forum and then Uploaded it into Fusion, everything worked fine, but I'm attaching it again.
Christoph
Christoph_360
Hello
Thank you for the support
I was able to solve the problem by connecting the Endpoint with a Support Circle.
Christoph
