- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I'm generally quite impressed with Fusion, but have been stuck at a problem, which I don't believe Fusion can accommodate.
I'm in the process of modeling a kitchen, wherein I want to model drawers under the countertop. The drawers come in different heights, widths, depths, etc. which allows us to play around with the visuals of the kitchen space. For that, I use parameters, which works fine.
The problem is that since I model the drawer in a separate file, there is no obvious way in which I can import and change parameters of linked models in my assembly.
I hoped Fusions configurations were the answer to my problems, but even this feature is "static". It still requires me to predefine any configuration of parameters in the drawer model file, and i cant make on the fly changes in the assembly.
Why is there no feature in Fusion that allows us to expose certain parameters of linked models, and assign values to them in the assembly?
E.g say I could make the width and height parameters "variable" when linking, then when viewing the parameters window in the assembly, under "Model parameters" and selecting the specific drawer object, I could assign values for height and width for that individual drawer.
Is there any workaround? Maybe configurations with an imported master file for parameters which could control both the assembly and drawer model file? It is not beautiful but...
Any input would be appreciated
Regards
