- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
Emboss feature seems to reach a limit with configuration feature.
In my design, I have a curved component with variable width depending on configuration.
The component has a an "EMBOSS" operation to emboss a sketch with rectangular pattern (slots) on his curved surface.
In the sketch, the pattern command has a parametric function that defines the number of the slots depending of the component width.
Now, when I switch from a configuration to another, it seems that the emboss command can't manage to select all the slots profiles created in the sketch. The results is that some slots are not embossed (but they are correctly calculated by the sketch).
It should be nice if the Emboss feature had a "select all profiles" option in the sketch reference.
Any suggestion to solve this?
