Configuration table order changes for unknown reason
Mublio
Message 1 of 22
Mublio
Hi all,
In my configured designs, the order of my configurations changes every now and then. This happens with almost all my files, but I have not been able to point to a specific moment. For example, I created the following configurations
Config 1
Config 2
Config 3
Config 4
Then, after a while, the rows of configurations looks like this
Config 1
Config 3
Config 4
Config 2
The Default configuration will always stays where it was, but the others seem to me randomly swapped. I have many configurations with a complex naming system, so its impossible to find the right one when shuffled. I know there's a search bar, but this is not available when you do nested configurations (which I do all the time).
Has anybody else experienced this issue?
Replies (21)
Message 2 of 22
gautham_kattethota
@Mublio
Can you give us a bit more context about this problem?  I take it that you save your Configured Design, close it and when you reopen it later on you see the rows have moved around?  Did you rename rows, deleted rows and undo, etc?  We have not encountered this problem before.  We understand it is not good for rows to move around randomly and we would like to fix this issue.  Any extra details you can give could help us.
Regards
Gautham
Gautham Kattethota
Software Development
Message 3 of 22
Mublio
Hello Gautham,
Thank you for the quick reply. I went back in the version history two files, and found the moment where the change happened. I cannot simply restore these versions, because weeks of work would be lost.
I can give you access to the files privately if that would help. I cannot see any major changes between the versions other than the order of the configurations changing.
Groet,
Koen
Message 4 of 22
Mublio
@gautham_kattethota I just had another instance of this issue occuring. Also, quite a few configurations where deleted, and one "Configuration 6" was added. In the screenshot below you can see the configuration dropdowns before (v94) and after (v95).
I noticed the configuration table of the corrupted version (v95) looks very different than the one thats still in tact.
v94
v95
Now that I look at this table again, this configuration table belongs to a whole other file that I have been working on. Somehow the file appears to load a configuration table that does not belong to this file.
In the browers and timeline everything looks just fine, see image above.
Hope this extra information helps!
Kind regards,
Koen
Message 5 of 22
gautham_kattethota
@Mublio
It is really strange that at a particular version of the CD, it starts pointing to another table.  Did you copy this CD at this point?  We might want to take a look at your files and request access.  I will get back to you on this.
Gautham
Gautham Kattethota
Message 6 of 22
Mublio
Hello Gautham,
The configured design was not copied at this time. However, the file originally was part of a bigger assembly, but it was split up in multiple separate configured files because of performace issues with the larger file.
Maybe the files are somehow still connected?
Kind regards,
Koen
Message 7 of 22
EvanGu
Hi @Mublio, if possible, could you please invite liang.gu@autodesk.com and yongting.zeng@autodesk.com to your hub? From v94 to v95, do you remember if you clicked Undo/Redo after deleting a configuration, or renamed configurations?
Evan Gu
Inventor/Fusion QA Engineer
Message 8 of 22
Mublio
I do not remember doing that. I invited you to the project and sent you a private message where to find the file. Just let me know if you need anything else.
Message 9 of 22
EvanGu
Thank you, @Mublio. We'll investigate it and get back to you
Evan Gu
Message 10 of 22
deepali.pulate
Hello @Mublio ,
I am trying to reproduce this issue, but unable to do so on my datasets. Is it possible for you to give me a access to your dataset, so that I can dig in more.
Thanks!
Message 11 of 22
deepali.pulate
Hi @Mublio ,
I am able to reproduce the first issue about order of configurations.
Performed following scenarios multiple times, where rename of rows, sorting rows, save and reopen of file is involved.
Will log a defect against it, Thanks for reporting the issue !
Message 12 of 22
Mublio
Hello @deepali.pulate, thanks for all the effort! Glad to hear you found the problem. Would it be possible to get an update if this bug is fixed somehow? Or would it appear in the "Whats New" blog?
Message 13 of 22
gautham_kattethota
@Mublio
We can let you know when this issue gets fixed and become part of a Fusion update.
I wanted to ask you about a comment you made in this thread "However, the file originally was part of a bigger assembly, but it was split up in multiple separate configured files because of performace issues with the larger file. ".  Can you elaborate on how you went about the process of breaking up a larger CD into smaller ones?
Gautham
Gautham Kattethota
Message 14 of 22
deepali.pulate
Hi @Mublio ,
Is it possible for you to give me the access of your datasets? wants to dig in more! While reproducing this issue the factors which I considered seems to be not working for me now, and unable to reproduce it on simple data sets. It will be good If I re-investigate and dig in more on this.
Apologies for the confusion!
Message 15 of 22
Mublio
Hello @gautham_kattethota, of course. First, we tried to design our whole cabinet system in one configured file. The file structure looked like this:
  • Cabinet assembly
    • Frame
    • Drawer
    • Door
    • etc.
Because we needed to have many configurations, this appraoch made the file incredibly slow. So we had to take another approach. We duplicated the "Cabinet assembly" file, and edited them so that each contained just one sub assembly (eg, Frame, Drawer, Door).
We now link those separate configured files into one assembly file.
Hope this helps!
Kind regards,
Koen
Message 16 of 22
Mublio
Of course. Could you share your email in a DM?
Kind regards,
Koen
Message 17 of 22
Mublio
@deepali.pulate @gautham_kattethota @EvanGu
I just had the same issue with another file, bit this time all the configurations disappeared including the default one (which is impossible to do manually).
What is truely worrying for me is that the problem persists even when I restore an older version. It appears like all the configuration data is just gone. This file is also derived from the original "Cabinet assembly" and edited like I described above.
I really hope you find the source for this behaviour, because I desparately need to use these files for our projects. Right now it is impossible to design any of our cabinets.
Kind regards,
Koen
Message 18 of 22
gautham_kattethota
@Mublio
This is troubling. Did you clear the cache?  Sometimes it does help to fix up issues.
Would you be willing to talk to us?  We can setup a call to talk through some of the critical problems you are encountering.  If yes, please reach out to me at KATTETG@AUTODESK.COM and I will work with you to setup a call.
Gautham
Gautham Kattethota
Message 19 of 22
Mublio
Hello Gautham,
Thanks for the quick response. I am familiar with the clear cache trick, but forgot to try it this time. A combination of Clear Cache + restoring an older version did the trick for this particular file. Thank you.
I would be happy to have a call to find the root cause, because this keeps happening all the time. I will send you an email.
Kind regards,
Koen
Message 20 of 22
deepali.pulate
Hi @Mublio ,
This table corruption is really disturbing!
I just wanted to know few things. Before this table corruption has happened may I know like which exact steps you performed? like Rename of rows, or sorting of rows? or any crash?
Some how I also ended up once with this table corruption on the previous dataset which you had shared earlier, where rows got deleted, but it was after the following scenario =>
1) Renamed multiple rows
2)Then performed sorting and after sorting it got crash
3) After reopening the file , renamed rows were deleted from table
I know we have a call scheduled for the same today, but it will help me to understand better.
