Mirroring a threaded hole through several components
alain_rogerNVLMR
alain_rogerNVLMR
I have 5 components and I designed a threaded hole on 1 side. The whole hole passes through all components.
However, when I want to mirror it on the other side of the active component,  the threded hole is mirrored only on the other side of active component and not through all other sides of all components.
So how can I do that ?
thx
johnsonshiue
Hi! Without seeing the actual design, I can only speculate. You may want to edit the Mirror feature and  change the Compute Type to Adjust. Or edit the Hole/Thread feature and include the patterned components in the Object to Cut list.
Many thanks!
Software Test Engineer
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
