- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Sorry if this is the wrong sub-forum, but there weren't many choices....
I am building a topper for my pickup truck out of foam, over which I will lay fiberglass. I tried to make the design simple, but I sort of failed 🙂
Actually, I am only failing at the math of figuring out the compound angles involved, and/or at the fusion skill of measuring an angle between two discrete intersections.
The problem is simple on its face. I have a rectangular shape I have sheared the edges of at 45 degrees. So in each corner there is a trianglular intersection of faces... there is a peaked roof at the top, so you can ignore the line coming in from the north...
Each surface is a piece of foam. Obviously the cut for the edges on the sides of the pieces that join horizontal and vertical pieces will be 22.5 degrees, as will the edges on the horizontal and vertical pieces themselves. And I naively thought ALL the angles would be 22.5, but of course where a 45 degree piece meets another 45 degree piece, there will be a different, sharper angle.... and I cannot for the life of me figure out what the math looks like to compute that angle!
Any help most welcome, thanks in advance!!
-eric
