Compute all loft problem!
macmanpb
macmanpb
If i make a "Compute all" always i get a message that a loft has no reference. I am starring over an hour to my sketches but cant figure out why.
Here is the file, hope you can help me out 🙂
http://a360.co/1KqFr4R
Phil.E
Thanks for posting. The Patch Loft command is losing the outer profiles so this is a case for development to look at.
In the mean time, have you tried doing a single extrude rather than all that work in lofting and Patch bodies? Any loft that can be done with extrude should probably be done with extrude, just to reduce the complexity of inputs.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
macmanpb
Thank you Phil to looking into that.
In the meantime i used extrude to get this done.
You are right, keep things simple as you can!
But i think also that the lost reference is a case vor the development team. 😉
Phil.E
Yep, it's logged.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
