Zoom problem
Zoom problem
andreas.walder
Message 1 of 12
Zoom problem
andreas.walder
Hi folks I am new to this forum and also in Fusion 360. I encountered a problem when zooming in into my part. If I reach a certain zoom level (not very high) the model is represented wrongly. It does not matter which perspective I choose. In the attached gif animation you have to look on the right side.
Who can help me please?
Greetings Andi
Replies (11)
Message 2 of 12
TrippyLighting
Does that problem persist when you cntinue to zoom and rotate the model ?
Message 3 of 12
chengyun.yang
Hi, I may know what is the reason for this issue. Would you please share your model with me so I can check it? You can either send me through email([email protected]) or give me a public share link. Thanks Chengyun Fusion Development Team
Message 4 of 12
andreas.walder
Hi I invited you ! Thanks for your effort!
And yes the problem is consistent however i move the part!
Message 5 of 12
chengyun.yang
Thanks!
I have reproduced this issue on my side using your model. One internal bug has been created to track this one and I am working on the fix for it.
This is the first time I saw this kind of problem. May I know how you created the base feature of this body? That might help me understand what operation could cause this issue.
Chengyun
Message 6 of 12
andreas.walder
I got the model as an *.step file and imported it into Fusion 360. Would it be helpful for you if I send you that file?
Greetings Andi
Message 7 of 12
chengyun.yang
Yes, please send me the original STEP file. Thanks!
Chengyun
Message 8 of 12
andreas.walder
Hi I attached the original *.step file which I included into Fusion 360!
Greetings Andi
Message 9 of 12
chengyun.yang
Got it. Thanks!
-Chengyun
Message 10 of 12
andreas.walder
Hey I just wanted to ask if there is any progress with this bug?
Greetings Andi
Message 11 of 12
chengyun.yang
We have fixed this problem internally. We are evaluating its impact to determine which release should include this fix. It is mostly likely it will be available in March release. But if this is blocking your work, we will see if we can push hard to get it to be released in our late Feb update.
Chengyun
Fusion Development
Message 12 of 12
andreas.walder
Wow nice that you could fix it. Smiley Happy I appreciate your effort. Actually this bug did not effect the CAM and therefore I already machined the part. So I am fine with the March release!
Thank you! Greetings
Andi
