I am trying to design a speaker box and so far I have created two components - The box and the speaker.
(samples below)
At this moment I don't know big and where the hole will be but I would like to make kind of assembly.
The question: Is there a way to give a view priority to a particular component in order to have it on top of other but not as the image below? Is it possible a component cut on place?
Regards
Solved by g-andresen. Go to Solution.
Please share the file then your questions can be addressed more specifically.
File > export > save as f3d on local drive > attach it to the next post.
günther
Here attached is the file.
Just to mention that this is just a sample and the shapes are not important.
The point is to have clear view of the green component (speaker) but not intersected as now.
Since the positioning (joint) is done before combining/cutting, the cutout in the box is also adjusted when changes are made.
günther
