Components and sub components active
jpadirl
Message 1 of 10
jpadirl
I have a component with many sub components. When I want to model in a sub component and keep the sketch and body in that component how do I keep the main and other components in view, otherwise it is difficult to see where to sketch.
Thanks for any help
Jpad
Replies (9)
Message 2 of 10
nemadec
If I understood your problem correctly, You want to keep other components visible while sketching in a sub-component:-
Solution 1: Use the Browser Tree Visibility Controls
The most direct approach is using the Browser (Design Tree) visibility controls:
  1. Keep the Browser panel visible - Press Ctrl+1 (Windows) or Cmd+1 (Mac) to toggle the Browser if it's hidden
  2. Use the "light bulb" icons in the Browser tree to control component visibility
    • Click the light bulb next to any component to make it visible/invisible
    • The active component will remain fully opaque
    • Other components can be kept visible but will appear semi-transparent for context
Solution 2: Use "Project Geometry" for Reference
When sketching in your sub-component:
  1. Start your sketch in the desired sub-component
  2. Use "Project/Include" commands to bring reference geometry from other components into your sketch:
    1. Go to Sketch → Project/Include → Project
    2. Select edges or faces from other components you need to reference
    3. This creates construction geometry in your current sketch for reference
Please let me know, if this is not the answer you were looking for.
Chandrashekhar Nemade
Sr. SQA Engineer
Message 3 of 10
g-andresen
try different settings
günther
Message 4 of 10
jpadirl
That setting was/is active.
Thanks for suggestion.
Best regards
Jpad
Message 5 of 10
jpadirl
That setting was/is active but does not show components at higher level.
Thanks very much
Jpad
Message 6 of 10
jpadirl
You understand my problem, however I am still having issue.
Thanks for your reply.
Still looking.
Jpad
Message 7 of 10
jpadirl
Still looking.
Jpad
Message 8 of 10
g-andresen
Please show your actions in a screencast.
günther
Message 9 of 10
laughingcreek
Thanks very much
Jpad
un-check the setting
Message 10 of 10
jpadirl
Brilliant, thanks very much.
Best regards
Jpad
