- Mute
- Permalink
- Report
Hello, I am needing help creating a tapered sweep profile. I have the basic geometry laid out on the far right pocket but have had no success shaping it the way I want.
My first issue is I cant move the outside pocket sketches down -.045 in the Z Axis which is where the top of the surface needs to be to connect to the other portion of the inner pocket.
The depth of the big part of the outside pockets needs to start at -.320 and they all need to sweep up to -.045 where the pockets get smaller. The outside edge needs to start with a .250 radius in the corner and finish at a .0625. The spline in the bottom of the right profile roughly shows that.
The angle on the inside of the pocket needs to maintain around 36 degrees. You can see that in my last sketch. Also, you can see this similar design if you turn on visibility on the inner profile. Basically this one sweeps up to a small radius of .0625.
The point of where the pockets start needs to have a much more steep angle down to the mold point on the bottom of the profile. I tried to show this with lines going down to the .250 diameter hole. There basically needs to be a radius there.
All three have similar starting and ending geometry but have different paths. Same angle and bottom radius profile though.
The closest I have come to success (haha) is when I first extruded the profile down -.320 and set my taper to -45. It basically had the shape I wanted except the back wall that should have a radius in the bottom was tapered as well. Now I cant even get this to work.
I would appreciate any help at all, this is literally my first fusion 3560 project. I've included some screen shots and my fusion file for this. Email me @ rbengston74@gmail.com or text or call at 6207556151 any time.
