Complex Shape Fails to Extrude
krummeck
krummeck
Good Evening
I am creating a cutting board. The elements include carving text, cutting an inner groove and cutting out the shape.
As a starter I have been unable to extrude the board shape, (complex shape), which in turn means I cannot carve the sauce groove and cannot carve the text. A real Mess.
Please advise as to where I went wrong.
Kind Regards
Warren Krummeck
jeff_strater
somehow, "Show Profile" has been turned off for this sketch.  If you turn it back on, things should work better:
Jeff Strater
Engineering Director
krummeck
I thought I would need to trade in my Fusion for a pencil 🤣
Rohan.bongale
Thankyou for Sharing your concern. Can you please share the steps or video.
I tried with the attached f3d, I am able to extrude the sketch.
Thank you,
Best RegardsRohan Bongale | Senior QA Engineer  | Autodesk India Pvt Ltd.
P. 20 6680 4444 | rohan.bongale@autodesk.com
jhackney1972
This issue is solved by message number 2 from @jeff_strater.  The poster of this question only needs to follow it and then mark message 2 with the Accept Solution icon to take it off the forum.
John Hackney, Retired
