Can't select sketch to loft
rudi4
Message 1 of 16
rudi4
Hi
My name is Lukas.
I am trying to design tire to my model and I got stuck.  I need to loft three surfaces (not flat). That what I did.
Three surface revolvers from sketch (arc to revolve), sketch intersected through each, and when I am trying to loft it- cant select any. Blue sketch is enable to select, but not intersected faces.
I'll be graceful for any tip
Lukas
Replies (15)
Message 2 of 16
Rohan.bongale
Thankyou fo sharing your concerns. Is it possible to share the design or video of the steps you are trying.
So that I can share the solution with you .
Thank you,
Best RegardsRohan Bongale | Senior QA Engineer  | Autodesk India Pvt Ltd.
P. 20 6680 4444 | [email protected]
Message 3 of 16
Rohan.bongale
We cannot select combination of sketch and bodies to create loft
Message 4 of 16
rudi4
Thank You for reply
This is not between body and sketch, just three intersected revolves (hope is understandable what I write).
Can make a Video but first I have to find out how...! I've never done it before hehe
But share design- how to do that?
Message 5 of 16
rudi4
I hope I got it.
I forgot to write then I've tried also project to surface but it is not active to select too.
There's link
https://autode.sk/3gXhCuL
Message 6 of 16
TheCADWhisperer
Message 7 of 16
jeff_strater
actually, you can create a solid loft between surface bodies and a sketch profile.  So, there must be something unique about your design that is preventing that selection.  As @TheCADWhisperer says, we'd need access to your design to see for sure what is going on.
Jeff Strater
Engineering Director
Message 8 of 16
rudi4
Thanks for all answers.
I made a similar design and I noticed, then if revolve is from straight line- loft function works. But if loft is from arc loft doesn't work.
Is that how it supposed to be?
I attached small fusion file
Message 9 of 16
jeff_strater
that seems like a bug to me.  I'll look into it.
Jeff Strater
Message 10 of 16
TrippyLighting
Just to be clear, you can get the same solid geometry with a surface loft and stitching.
Message 11 of 16
rudi4
Yes that's working, it's truth.
I'll do it that way, if there won't be any solution, but I cant understand why it was working before.
Around two years ago, that way (revolve-intersect-loft) was working fine with previous model.
Message 12 of 16
TrippyLighting
@rudi4 wrote:
... but I cant understand why it was working before.
Although it might sound counterintuitive given that a bug might have been discovered, there have been a number of nice improvements in the loft tool over the last 2 years ad development on the tool continues to progress.
Message 13 of 16
jeff_strater
I spent a fair amount of time (probably more than I should, but once I got started, curiosity took over) today chasing this bug down.  I found the bug - we are specifically disallowing selections of spherical or toroidal faces in Loft.  I think I found when this change went in, and (while it is possible that I am misreading the history here) it looks like this was done about 7 years ago.  There could easily be other things going on, but that is my current understanding.  Anyway, this is a bug, and we will get a fix for it.  The Fusion bug is FUS-89984.  Thanks for reporting it!
Jeff Strater
Message 14 of 16
rudi4
Thank You very much, Jeff 😀👍
I've spend many evening to figure it out, what I did wrong.  It's big relief to know the reason 😅  Thank You again.
I attached a test file. It is a part of design I mentioned earlier. It is, like as said around two years old. I used function face offset, but it is from spherical revolve too- it went fine then.
Could You be so kind and take a look on it?
About bug- can I make any upgrade to fix  that bug? If yes- how? I don't see any upgrade option 🙄
Message 15 of 16
jeff_strater
I've looked at this design.  The input surfaces for both lofts are actually cylindrical, not spherical.  I haven't looked into the details yet, but my debug tools show cylinders
Jeff Strater
Message 16 of 16
rudi4
Jeff, You are right in 100%.
Now I noticed the differences now. In test2 file all is from cylindrical revolve. I used spherical surface, just to cut the body after loft, to obtain final shape.
My bad.
Solved, clear and understandable for me. 👍
Thank You
