How to import sketch from FreeCAD
gla1972
gla1972
Hello, how do I import the Sketch from FreeCAD into Fusion 360 (with its dimensions and restrictions) only.
Thanks!
jeff_strater
I'm pretty sure that is not possible.  I don't know anything about Freecad or its sketches, but I do know that the only way to import sketch geometry into Fusion is via DXF or SVG, and no dimensions or constraints will come with those formats.
Jeff Strater
Engineering Director
TrippyLighting
I don't know of a single CAD application that takes sketches and associated constraints from another CAD application.
I know quite a few CAD applications after 3 decades of professional CAD work.
gla1972
Thanks for reply!
Kzinty
If you export DXF or SVG with 3d data you can import it into a sketch using insert. The data will come in as a 3D sketch.
